- 634
- 13
- 18
- Cordova, Alaska
Has anybody removed the hydraulic head without lining up the timing mark? I just f**ked up and did, now I am trying to figure out how to line everything up to install the new one. Thanks for the help.
You must have had a time getting it out. the gear has a spot in it that is missing some teeth that let's it pop right out. Why did You remove it?
I looked through the IP TM and did not see any info regarding timing for the head, so I um... just took it off. Then figureing things out I moved the engine messing with the timing. Now I have the stuff lined up and in. It runs above 1000 rpm but wont idle. Either its 180 out or just air in the lines.Didn't you have the marked tooth aligned in the window below the HH to remove and replace
it?
I thought I had all of the manuals . 1 more to the list. Thanks you.TM 9-2815-210-34-2-2 section 5 pages 168-182
Exactly. The timing marks on the crank need to be aligned WITH #1 in TDC firing, not exhaust. You will have to turn the engine over with the front valve cover removed. Once you see the crank timing mark, note the movement of the valves while slowly turning the crank. If the valves move, rotate crank another turn, then position crank timing marks aligned.just line up the notch in the plate that covers the drive gear. line up the head gear with the red tooth and pointer. if the red is gone it is the tooth with a fine line scored in it. if it won't idle you may have a bad head as at low rpm a worn plunger will not open the injectors. warning: none of the timing marks on damper or under the little plate have anything to do with timing the hyd head. it either runs or it does not there is no such thing as 180 out.
Guess its time for another head. This time it should be an easy swap.if it won't idle you may have a bad head as at low rpm a worn plunger will not open the injectors.
Like your Austern Western bed thread-adapter PM?Please post your phone conversation, so we can all learn...
