if you are getting lube in the steer axle wheel bearings then you have a inner axle seal leak. it's got nothing to do with key way seals. you will need a slide hammer to remove the seal carrier after taking the whole knuckle apart. You must have a very good knuckle boot in order for it to hold gear lube and force it into the wheel bearing.Its a bobber and the lube is getting to the bearings in the front end. Overfull I'd say. Going to the parts store right now.
i think you gave me that same advise on mine. i had the same problem with the same side on the front axle. changed everything out then started leaking again. my retainer wouldnt stay seated in the axle housing correctly. when i pulled it all apart again the retainer (seal and everything) came out with the axle shaft. i cleaned everything really good with brake cleaner. put silicone in the seal area with a brand new seal then jb welded the retainer into the axle housing and let it dry overnight. the next day i put a little grease on the seal lip, cleaned the axle surface, and reinstalled everything with 4 lbs of new grease. so far so good. (fingers crossed) reading this almost makes me want to go check it again, but im scared!Did you seal the retainer ring into the axle housing? I had mine leak after the repair. I then RTV the seal into the retainer then glued the retainer into the axle. No more leak. The seals flat side faces outward. Make sure you grease the seals lip too.
....so far so good. (fingers crossed) reading this almost makes me want to go check it again, but im scared!
just went outside and checked. STILL GOOD!
OH, Let's see....Are you kidding evrytime I come out of a store and see fluids on the ground regardless if it was already there it scares the crap out of me. God knows why ......lets see new motor new radiator, break booster, mastercylinder, ,rotors, pads, hosesand a fuel pump **** whats left to worry about
Probably just an old seal who's time was up!what would cause a sudden massive leak in the axle seal?!?!?! Every other wheel is dry except one. just..... BAM! leaking a good amount of fluid. I'm on the fence about just doing that one... or if I should do them all.... but if they are not broke dont fix them...right?....
I've never had to fix one of these...oh yeah.... and not to jack the thread... my engine stop cable broke today... I had to pull the plunger out on the injector pump w/ pliers..but thats getting old..quick! how do i fix that???
sorry for the quick highjacking!!!
They might be but the surplus market prices and ease of ordering are not too bad. For instance Erik's has a brake cylinder for $26 NIB.I've got a leaker on the left rear wheel. I know I can purchase the parts online but are they available at a local parts house First time attempting to do a repair like this on the deuce
