- 8,279
- 619
- Corpus Christi, TX
Organization:398TH CHEMICAL COMPANY Location:MILLINGTONa. 12514946 (I think there is supposed to be a "0" in front of the 125). The data plate stamping begins at 125.
b. Registration number is painted over, cannot read it.
c. 23200771617
d. Fort Gillem Forest Park, GA
e. Passenger Front= 81C-R398C Driver's Front= 212
Clinto thinks this should be a Kaiser-Jeep but GL said this was a General Products Division truck. He also thinks the 0125 serial # is '66 or '67 so that should be right. The data plate is for a Deuce with a winch and you can see where the PTO handle used to come through the floor for the PTO.
Much thanks!
She who must obtain a DUKW.........![]()
TENNESSEE Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 NSN:
2320000771616 Serial Number:
12514946 Registration Number:
4G8938 Year of Mfg:
1965 Manufacturer:
65909
Usage Miles: 40000
Sep 04
I would bet the usage miles is a fudge.
Keep in mind CAGE CODE/BINCS data base was developed in 1974 so at that time they would have went back in time to develop a CAGE number for Kaiser Jeep. In 1974 it got registered as simply Jeep and only later did they develop a CAGE for Kaiser Jeep. It seems this is the same for all trucks pre 74 and a lot post 74. Most likely as they built the database they did active production first (actually companies request their own in order to do business with the govt) and then worried about previous producers no longer around.
