- 10,350
- 92
- 48
- Meadows of Dan, Virginia
Do they all have one and is it electric or air operated? Thanks.
What are you driving? Fan noise in cab=m656/xm757, if so, any pictures?Hello Crane truck. I have had the same idea and have been wondering it it would be possible to be done !! It would be much quiter in the cab while driving without all that Fan noise !! post lots of pictures if you can make it work !!
A fan clutch won't work for what you are wanting to do (unless I'm missing something). Should be able to find a small air cylinder off of e-bay or something to fit your needs.BTW, that's not what I want to do, I'm looking for a good actuator for the hydraulic retarder on the transmission. A spring loaded pneumatic piston with a 1/2 inch travel.
you also may want to watch for shutter stat products.Well, it goes to show how little I know about this series...saw this (image) and wanted to dig deeper. How and where is this item used? If it's still on the parts truck, I may be able to use it for my 8x8 hydraulic retarder.
I drive a M813A1 and the M809 Truck have the Cummins and the fan is direct drive and it is wnat causes the noise !! If a fan clutch could be installed it would help reduce the noise that the Cummins makes !! I wonder is a Electric fan could be installed to help get more power out of the Cummins ??? HUMMMMMM !!!
