tsmall07
- 4
- 0
- Springfield, VA
...but it has split ring wheels (at least in the front). I thought you couldn't run split ring wheels with radials. Am I wrong? Does this mean my radials have tubes in them? ![Question :?: :?:](https://www.steelsoldiers.com/images/smilies/icon_question.gif)
![Rolling Eyes :roll: :roll:](https://www.steelsoldiers.com/images/smilies/icon_rolleyes.gif)
Yes, yes...and you need to take them off immediately....and put them on a pallet and send them to me!...but it has split ring wheels (at least in the front). I thought you couldn't run split ring wheels with radials. Am I wrong? Does this mean my radials have tubes in them?![]()
Even though it's busted??My Bubble is still fine.
sorry to bust your bubble guys, but you can put tubeless radials on split ring wheels IF the wheel is designed for tubeless like the m-757, m-656. they came tubeless. of course this is a very rare example, but never say never!!
Tube type radials are perfectly fine....but it has split ring wheels (at least in the front). I thought you couldn't run split ring wheels with radials. Am I wrong? Does this mean my radials have tubes in them?![]()
The 9.00 tube is gonna be stretched thin to fill that tire. That plus all the friction between the tube and tire in the sidewall area will equal a short life expectancy for the tube.I am proly gonna get slaughtered for this but I have the 395-80R20 Michelins on my deuce with the standard snap ring rims and........bias 9.00-20 tubes. I could not get 14.00 radial tubes when I put the tires/wheels together this summer. I asked a bunch of truck drivers I know and their tire repair/suppliers. They said to just run what I got and keep an eye on the tire pressures. Aired up to 75 on the highway and down to 15 off road. Empty and with a load. So far, knock on wood, no problems.
Now that I have said it.....Commence firing, fire at will.![]()
I have radials all around, including the spare. I just wasn't sure if the rears were split ring because I haven't looked close and the ring would be on the inside of the duals. I assume they are the same type of wheel as the front. I'll have to save for some different wheels when I need new tires. My tires are brand new so I don't have to worry about it for a while.If your " M35" is a on road truck you may want to check the law. In Texas it is illegal to run mixed tires " radials and bias ply" In VA??? no clue.
