CDR valves - Whos got em?
BIG_RED
Winnipeg, Manitoba
I can't find a CDR valve anywhere.. not even a civvy one. Not on rockauto. Not at a GM dealer. Parts chains. Nowhere. Anyone still selling these things?
Wolf.Dose
9
Boehl-Iggelheim, Germany
Sorry, may be I'm stupid. I drove a CUCV truck 16 years. But what do you mean with a CDR valve? I think I know almost any valve in these trucks, at least their function. May be I know that valve in German, but the abriviation I do not know.
Wolf
BIG_RED
Winnipeg, Manitoba
It stands for crankcase depression regulator. Basically, it sucks the blowby out of your crankcase with a light vacuum into your intake (that's my understanding). When they don't work, your intake starts sucking oil through it, or your crankcase builds up pressure and leaks everywhere. The CDR valve sits on the passenger side valve cover on an M1009. It looks like a brass tuna can.
You have one? I could only find one and it was for something like $80. How much is yours? Maybe send me a link if you don't mind. Thanks.
notsosanestan
NNJ
i have some smoke coming out of my oil tube and oil filler when the truck is running is this common with a bad CDR valve?
CUCV85
central/ny
I believe that the CDR Valve is not working,
that the oil filler tube cap has a venting function
for this reason as a back up - the civilian 6.2 oil filler cap
was flat with no venting capabilities...
Shake the oil tube cap it should rattle freely!
This may seem silly, but to clean parts with rubber in them, wouldn't it be better to use brake cleaner? I have been using it for years to clean any parts consisting of rubber, and then usually I will spray them off with silicon oil to add some protection. Makes them look pretty as new usually.
Discuss?
