Part number needed
motormayhem
Tucson, AZ
Does anyone have the part number for the radiator puke tank for an m1009? Autozone website says they dont have it and mine is cracked. It is a nuisance because if I get on the throttle for a day or work the engine hard the the radiator pukes out the overflow and the fluid is lost and the radiator gets down on fluid.
12vctd
Junction City KS
I dont have the part number but till you can find a replacement, a gallon jug just like the antifreeze comes in will work for a temp fix, and a few well placed zip ties or bungee's.
doghead
4 Star General /Moderator
1,191
Here's a start, right out of the -20P
14052221 TANK,RADIATOR,OVERFLOW
CARNAC
The Envelope Please.
697
Corpus Christi, TX
11 14011345 CAP ASSY
Cage CdManufacturer Part Number
11862 14011345
11862 371978
7X677 14011345
13 14052221 TANK,RADIATOR,OVERF
11862 14052221
7X677 14052221
SCY13 2930011592902
motormayhem
Tucson, AZ
So this is going to be a hard to find military specific item and it would be faster/cheaper to buy a different one and make it fit?
7X677
Detroit / MI
14052221 is still in stock. There are 114 in GM national inventory. List price is $26.17.
PART REINSTATED FOR CUCV USAGE PER ECA P9T00636(WAS REPL BY 15595742)
jj
Kutztown,PA
That ----2221 number is a good one, so is the price. My local Chevy store had one in stock (?) about a year and a half ago. The counterman never even batted an eye.
Crash_AF
Colorado Springs, CO
Dude, I had no idea to even ask at the dealer since it is a mil specific application, but thanks for providing the info. [thumbzup]
Later,
Joe
motormayhem
Tucson, AZ
The napa part number I gave also is the correct tank. The only difference is the mounting bracket on the top where the bolt goes in, but you can bend it to fit while you tighten it down and then it is all perfect and like it should be.
doghead
1,191
Later,
Joe
If you own an MV, you really should consider downloading all the TMs that pertain to your vehicle.
Many of the -20P part numbers are GM part numbers(I've said this before).
Simply finding the picture with the part, then the number for the part, then a Google search of the part number, will often find the part you need.
Also, just SEARCHING the SS site for the part name, will often be helpful.
doghead
1,191
I really like that google thing! Believe it or not, some people just wont help themselves by searching! You'd think they might try helping themselves by having the TMs saved on their own computer or in hardcopys, to have at the ready, whenever something needs fixing. This site has grown to the point that most every issue has been discussed at some-point. I realise it's difficult to find the information you need, sometimes but, when in need of a part or info, there is no better way to ID the part(and start a search for it) than to look at the TM with parts pictures, numbers and names.
