jakwi
- 0
- 6
- Colorado Springs
I've been lurking here on SS for a while now and I thought I should introduce myself. I am the recent owner of an 86 m1009
Thus far it has been running pretty well other than an intermitent stall on deceleration issue and also mildly surging idle. (any ideas? I've already bumped the idle up maybe an eighth of a turn.)
The passenger door also rubs on the forward edge against the fender. It looks like a replacement door as the camo pattern doesn't match. I'm not sure whether I should be trying to move the door or the fender, It looks like the door isn't properly centered, but I don't see any adjustment.
I haven't made any changes to it other than installing a cigarette lighter.
and installing a 2" ball/pintle from harbor freight. The PO converted it to 12v and installed a temp guage. I also fixed the horn with two ball point pens and some heat shrink. but it works now so that's good.
I plan on fixing the holes in the floor and installing some insulation/vinyl floor, changing out the front seats, I've been thinking about tinting the windows and maybe painting it. A dome light and a stereo of some sort would be nice.
In the future I'd like to put 33 inch tires on it, from what I've read I can do this even without lift, but I am not sure about the backspacing on the rims. If anyone knows how much backspacing is needed I'd love to know.
This is my daily driver now, so mostly I'd like to reduce the noise and make it a wee bit more comfortable.
anyway I guess that's it, I'm in colorado springs.
