Napoleon_Tanerite
- 3
- 0
- Warner Robins GA
Ok, so you probably remember my thread from a few days ago about replacing the door hinge pins and bushings. Well I ended up just taking the door off by removing the bolts from the door side hinges while leaving the body side hinge piece in place. I made short work of the old pins and bushings, but now I can't get the new bushings in. They're SEVERAL sizes too big for the hole, I'd estimate 1/8" too big. I can't believe I'm supposed to drill the hole out, so what's the trick? A quick whack with the hammer did nothing but bounce the bushing down into the body panel (gotta get the vacuum out when I'm done with this post).
So again I ask for help! This time the TM doesn't help me out.
