Blood_of_Tyrants
- 10
- 38
- Lebanon, TN
So, I'm looking to replace the open differential in the front axle of my M1009 with a limited slip differential and have a few questions. Seems to be a fairly cheap mod with used diffs going for $100 or so.
First, how many splines does the front axle shaft have?
Second, can I reuse the stock 3.08 gears (assuming they aren't shot)?
Third, I have heard that you don't use standard gear lube for a limited slip differential. is this true? If so, what is the proper lubricant? Do I need to clean the axle housing and get the gear lube out?
Fourth, do I need to reset the gear lash? (I wouldn't think so as long as I use the same thickness gasket on the differential housing.)
Fifth, do I need to make sure that the 3.08 gears will fit or are ring gears a universal fit?
Sixth, what do I need to make sure is included except for gaskets and seals?
Seventh, are there any brands to avoid?
Last, is there anything particular that is a warning flag when buying a used limited slip diff?
