AJMBLAZER
- 8
- 0
- Paducah, KY
Good point, I didn't notice the locked out part.
Only the rear on a stock M1009 has a Grenade Lock in it.
You wont be able to do the job with the carrier in the housing, or at least reasonably. Honestly its not that hard to jam a lunchbox locker if your using the same carrier, you dont need any special tools despite what proper methods say. Removing the carrier goes like - remove wheels, rotor, spindle, axle shafts, cover, main bearing bolts (4), make sure you put a nice soft mat for the carrier to land on and chain up the carrier and yank it out with the chain tied to your vehicle of choice. Easy as cake right? (not)
To ram the carrier back in, if your reusing the carrier and spacers, tap on the carrier using your favorite mallet, until you can thread the bearing caps and use those to cram the carrier back into the case and reverse steps to reassemble. No axle spreader needed!
In all seriousness, the best way i've found is to use a block of fake wood (trex) and use it for a pad on the pinion snout. I'ts a nice even push on the carrier. I generally use a couple strategically placd blocks of wood with a pillow to catch the falling carrier if a buddy is not available. Good luckCan I use a Come-along to pull it out? Seems like it will be a lot gentler.
Yup, suitable pry bar, whatever you have laying around at the time. Scrambled put out a good point, dont listen to the whole churn the carrier in with the bolts my ideas are usually prettyCan I use a Come-along to pull it out? Seems like it will be a lot gentler.
Depends on what you use your truck for. For a lot of people... locking it in on the street doesn't happen much. Like me... I would say that 95% of the time I lock it in... I am not on the road. So, I will gladly give up a little road manners for a huge improvement in off road ability, and I mean HUGE.lockers have terrible road manners,
Thanks for the advice, but on the road, the truck will probably be int 2wd and the hub locks turned to free-wheel. But thanks for the advice about the snow.lockers have terrible road manners, hope your planning on mostly off road use of the vehicle. A good limited slip is still the best choice in my opinion..something with a high bias ratio of 3.0 or more (max is 3.5). You can get better results from a posi too by using the brakes a little when one tire is in the air. But, if your wheelin' with a tire in the air....rather than put a lunch box locker in a half ton truck, you oughta spend that dough on a drivetrain worthy of that operation. Lastly, dont drive in the snow with the locker engaged or you'll have to do a 4 point turn at any intersection. good luck
