BII on M-116 Trailer w/ MEP-003A GenSet
m38inmaine
102
Maine USA
8lb sledge hammer, 2ea ground rods, slide hammer, fire ext(BII), and manual(BII). Last two items are the BII, others are in the accy. box.
gunboy1656
24
Beaver Falls, PA
Those are for an antenna (9M or 15 meter). the set came from a signal unit. Pulled many of those.
The 3rd pic is for your ground strap.
The tie points at the back are for the 2 part power cord.
steelandcanvas
87
Southwestern Idaho
Thanks Scott, So the 6 sided clamp is for an antenna, is really not needed if I don't plan on using it to support a signal unit. The other straps are for ground and power cabling, so I'll leave those intact. I'd like to re-mount the Genset in my M105A2 trailer and use the M116 for my ATV and lightweight hauling. The 105 lines up with the Deuce, better than the 116. The 116 lines up real nice with my Dodge Cummins Dually, so I figured a transplant was a good idea.[thumbzup]
