TexAndy
- 15
- 38
- Bee County, Texas
Background:
Got a 1009 off GL a few months ago. It has no starter. So I borrowed a friend's (broken housing) to bolt up temporarily just to test the engine.
How do I know which cables hook up to which posts on the starter? In the TM, it says "when replacing, take note of which cable goes where" (paraphrase)... unfortunately, mine didn't come with one, so I don't know how it was hooked up to begin with.
Also, there's a big thick cable with red insulation coming from the engine compartment that looks like it's supposed to come back farther (maybe one of the starter cables?) but it's cut. It looks about as thick as a battery cable.
In the TM (-20), on page 4-12, it shows one wire going to the solenoid attached to the motor and another wire going to the motor... if these are both positive, where does the ground go? Is the whole thing grounded through the housing to the engine block?
Also... how does this work with the starter relay? In the TM, the relay looks like it's in a totally different spot. Do I even need to worry about it if it's already hooked up to the wiring harness through those special connectors like it shows in the TM?
1009 is down the road about 30 miles at a friend's place, so I can't go outside and look. Any help, pictures, advice ya'll could throw at my ignorant butt would be most appreciated.
