groundog
- 0
- 0
- wittmann,az
![Driver :driver: :driver:](https://www.steelsoldiers.com/images/smilies/driver.gif)
I know that some folks on SS will purchase the factory O-Ring for the wheels, I on the other hand choose to make my own.need help---disassembled my 5 ton combat wheel to re-place tire---1400 x 20--the o-ring is shaped more like a fan belt---this wheel has the 20 outer bolts-----is this the right seal----it is definitely triangle shaped---thanks
Doest it leak at this spot?You can use "Crazy glue " or weather strip adhesive to join the ends together.
I cut the O-ring material on an angle, then glue. Because they are sandwiched between to plates the O-rings don't move, and they don't leak.Doest it leak at this spot?
