Amxhunter
- 0
- 0
- Mobile, Alabama
Thought i would do some milestone updates as i get things slowly moving along.
After finally coming up with a Steering Box WITH a Pittman arm and the seller included the universal joint and a sliding column , we are making progress.
Here are some shots of the progress.
The PS Box has a large output shaft and as one other one the board noted , a cutout to service the seal is a nice addition and that's what's happening here. Got the outside plate cutout to 4" and use that for a template to cut the frame.
Also , going a different route on the pittman arm, I found a 1.25" Sway Control Ball that fits the factory drag link.
the Pittman arm hole is slightly large and will be bushed to take the load and then just for safety , welded to the arm.
This dang PS Box is Heavy ! about 60 lbs. having a lot of fun getting it up and into place, what a butt buster !!!
Also on the frame shot you can see the lines on top of the frame rail , getting ready to trim that out.
This mod is definitely not plug and play , but the end result will be worth it.
