What to do after flooding?
Mark3395
Geneseo Illinois
Had a bi t of a flood that put water just over the hubs of a couple CUCVs and a couple deuces. don't think it reached the vent caps of the deuces.
What teardown/cleaning do you recommend?
What a mess.
Thanks.
ken
25
Houston Texas
Mark, Wheel bearings! Clean and repack. Don't let them sit too long They will rust on you. The duece's front axle will need a teardown. The axle shaft bushings will need a cleaning and repacking also. And of course pull the axle fill plugs and check for water.
Hkx3
Cincinnati, Ohio
How is this any different than the many many videos/experiences Ive seen/had where axles on the duece, and other 1/2 tons like your CUCV were submerged while running repeatedly?
Honestly I thought nothing would be harmed if the seals were intact.
God knows Ive submerged truck and Jeep axles well over the tires for hours on end with no ill effect.
Heavysteven
10
Hickory Flat Ga
Useless you have new seals and a new gasket on the outside of the hub there a possiblity water got into the hub.
Really not that hard, lift the front axle, pull the hubs off, and take a look.
markmontana
Mesquite, NV/Layton, UT
Mark- this is what I would do (what heavysteven said). Take the truck that got the most water, or one you haven't done the bearings on, and take it apart and check. You'll know right away if the others may need attention, and how much you'll need to do.
