jesusgatos
- 28
- 38
- on the road - in CA right now
Just posted this over on pirate4x4, but I know there are a lot of people on here that know a lot about hydraulics too, and I'd appreciate any helpful input on this subject.
I know - it's not possible to fail-proof anything. But I'm building an offroad-oriented motorhome (M109 conversion) that I want to convert over to a full hydraulic steering setup, and I want to make it as safe as possible. This is a BIG truck (16,000lbs empty) and I'm going to be driving it on public roads. Plus, I'm going to be living in it full-time and, well, I don't want to crash my house.
The M35A2's all came with manual steering, and it's actually not as bad as I was expecting; at least when the truck is moving and the road is smooth/paved. But maneuvering in parking lots and steering through rough terrain is absolutely brutal. The M35A3's were outfitted with air-assisted power steering systems, and those air-assisted power steering systems were also retrofitted to some of the M35A2's. But I'm not at all interested in going that route. There is limited room to retrofit another (power) steering box, and no real way to run any type of crossover steering linkage. So here I am. I'm NOT asking whether or not I should run full-hydro steering on the street, so please don't turn this into another debate about whether or not full-hydro steering is legal/safe/etc. I'm comfortable with the idea of running full-hydro steering on the street - I'm only trying to figure out how to design and build the best/safest system for this application.
I've read through all the relevant threads that I could find, and I've read Billavista's tech articles. I know that all the components need to be carefully selected in order to create a balanced system, and let's just assume that the whole system will be regularly inspected and properly maintained. In some of the past discussions about running full-hydro steering on the street, we've talked about the back-up systems that they use in things like airplanes. I'd like to figure out whether it's possible/practical to design/build some kind of similar redundancy into this kind of steering system.
I'm most concerned about blowing pressure lines/hoses, as that's probably the type of failure that's most likely to result in a total loss of steering, right? I'm not too concerned about losing power/pressure, as that wouldn't be any worse than what I've got now (manual steering). But I guess the steering unit could fail somehow, or the ram/s could blow apart. Am I overlooking any other (realistic) types of potentially catastrophic failures that should be considered/addressed?
Having two completely separate/redundant hydraulic steering systems seems like one obvious solution, and that wouldn't be too difficult. But I'm wondering if I really need to double-up on EVERYTHING.
Is there any way to design/build a system that has two separate hydraulic circuits without using two pumps? I just don't have enough room to install a 2nd pump (at least not one that's engine-driven). I'm planning on using the stock 5-ton/LDS multifuel engine's power-steering pump. The specs on these pumps vary a little bit, but they're all positive-displacement type pumps, and they put out between 5-6gpm at 1000-1500psi (more info here). Could that be done with check-valves or something? Doesn't seem like that would be a problem.
What about the reservoir/s? Would it be a bad idea to use a common reservoir? I know that eventually a blown line would drain the system, but I'm going to have an extra-large reservoir (10-20 gallons) because I've also got a transfercase-mounted hydraulic PTO unit on this vehicle. I've got to use multiple reservoirs anyway due to space constraints, but I would like to be able to run all of the hydraulic fluid through the same filtration system if at all possible.
And what about the steering unit? I'm totally stumped here. No idea how to control two separate hydraulic systems with one steering unit. Is it just a matter of creative plumbing, or would I need a different type of steering unit? I definitely want to use something that's load-reactive, and I would like it to have a power-beyond port, but that's not essential.
After considering all the options (at least that I'm aware of), I think I'd like to use two cross-linked rams, mounted sort of like this:
But can I use unbalanced rams that aren't cross-linked?
I would consider using a single/balanced/centered ram, but I'm not thrilled about the side-loads. Especially on such a big heavy vehicle that's going to see a lot of street miles. Plus I like the fact that with two rams, I'd still have a backup if I lost one. More common and less expensive too (service/replacement).
Not sure how I'd use one (or more) of these, but I thought it was pretty cool:
![](http://www.pirate4x4.com/tech/billavista/PR-Hydro_Steering/images/crossconnected.jpg)
![](http://www.pirate4x4.com/tech/billavista/PR-Hydro_Steering/images/10-9.jpg)
