My recovery story. Fort Polk, LA 8-14-10
progun
Duson, LA
We arrived on post at 0900. It was My uncle (who works at Fort Polk), his son Ben, my friend Jeremy and myself. I got Jeremy to start installing the guage set while Ben started to remove the batteries. The batteries were new in 07 and I think they will take a charge! First thing I did was open the air box. The filter is NEW! I mean not an hour on it! I then pulled the dipstick to find beautiful oil the color of honey, just changed! On to the brakes.. reservoir full, bled a little out of each wheel and no air and the fluid was new. New radiator (from 07) with pretty green coolant. Nice belts. We installed two new 850 CCA batteries and it was time to see if she ran. I cranked it over with the fuel shut off for a few secs to make sure there was no fluid in the cylinders. Fuel on and ..... vroom! She fired up like she was run yeaterday!!! Sounded great, charging, air building press., oil pressure good. All systems go, time to air up the tires and drive. Pushed in the clutch and put the transfer case in high. The stick was in "neutral" position so I went to let out the clutch and the truck lurched forward! What?? I stirred the stick around and found a gear. Clutch out... truck bogs. Not good, I think, I got a bad tranny. It would go in second though so I made a block slowly. Finally, we pulled the top off the tranny to see what was up. Turns out, whomever worked on her last jammed the rear shift fork forward beyond the detents sticking the box in first gear. Any other gear than second was also in first, thus the bogging. Put her back together and away we went! Drove just over 50 MPH and the trip home was fun and un-eventful. The only thing I don't have is lights... none. I think the problem is the switch (it's marked 'good" in 09). Thank y'all for you help so far and thanks to the guys that rode there with me!
progun
Duson, LA
Yes, that's what we were thinking because otherwise all is good. I'm glad they did all the maintenance to it. BTW, this was a very fun day for us and we will always remember it. Here she is at home!
progun
Duson, LA
I wish I knew. I'd love to know if it went to Vietnam and what it did in the desert. I got no records of any kind. Just the truck with no guages. Yes, a keeper indeed!
Heavysteven
10
Hickory Flat Ga
Progun, looks very nice. CARC tan is becoming popular.
I would still change all the fuilds if it was me. Always, repack the bearings. Of course it been 9 months and I still have the radiator to fix, bleed the brakes, and repack the rears.
progun
Duson, LA
Yes, I will do the bearings and the boots. The tan is cool but being an airman I am going with 1970's Air Force green..... eventually
fasttruck
632
Mesa, AZ
Power up to the switch ? if so jump from the hot lead to another position on the plug and see if anything lights up."f" on the plug is power in and "m" is the headlight circut. switch also has its own circut breaker which if tripped wouild suggest a short.
runk
65
Houston, TX
Don't be too quick to blame the light switch. Almost no lights on mine when I got it, swapped in a new switch, no better. Dug into the wiring and found a combination of burned out bulbs, broken wires and bad grounds. Whoever was responsible for the maintenance of my truck in the Ark. NG did not like to do electrical ! (Like yours all new fluids, everything mechanical was in great shape.)
mkcoen
381
Spring Branch, TX
I hope you have better luck than I did. I picked up a 1009 a couple months back and the batteries were delivered in '08. I can get one of them up to 8volts but the other one won't get above 3.5 no matter how long it's charged. I'm thinking about dumping the acid and refilling it to see if that helps. I hate to throw out (well, turn in for cores) something that new but they just won't seem to come back.
