I had a minor coolant leak that turned major as the crack in my crossover pipe kept getting bigger, I knew it was there, but kept saying i would fix it later. Well the leak got worse and drained down across the starter and soaked it a few times before i replaced the broken pipe. In the meantime my starter was acting funny. It would slowly crank and then fire, acting like the battery was dying. Once started it ran fine, but has gotten worse the last few times i have starter her up.
I checked the batteries and alternators and all were good. Lights do not dim in the least either. So the question is could the coolant leak have caused some issues within the starter?
thanks
thanks
and with anti freeze as it drys if you drive on dusty /dirt roads the anti freeze acts as magnet for dirt/dust. Have it checked or it just may need a good cleaning! Take it apart clean everything and if find or see no problems put it together and give it a try! may save a few bucks!
