fuel filters
Maverick1701
208
Lubbock, TX
several of the sponsors have kits w/all filters and gaskets for around $60 IIRC
eriks military surplus
OD iron
etc.
There is also a napa/autozone etc cross refernece list posted in the resources section if you decide to buy from a local dealer.
Chevyman_15237
Pittsburgh, PA
Give Napa a shot... primary fuel filter (part number 3511) runs $7.71 and the secondaries are (part number 3512) $9.29 a piece. Might be cheaper to buy them there, save on shipping. Napa filters are made by wix... from what I heard Wix had the gov't contract for filters... that could be heresay, but the napa ones work for me!
gunner_bear
grand haven mi
napa filter
is there anything that has to be done special to use the napa filters? any different gaskets? just remove current filter and replace with the napa?
LowTech
162
Arizona
I just replaced mine w/ locals from Car Quest.
the primary was #86511, and the secondary & final were #86512.
one of the gaskets in the primary worked, for the seconds I needed to order 2x gasket #90070.
I think these NAPA #'s are good;
Prime - #3511
Sec - #3512
gaskets for seconds, - #5070
jatonka
111
Ephratah, New York
Napa gasket for OEM primary is #5131
Napa Gasket for the secondaries is #5070
There is no perfect primary available at any car parts place, military primary is different. The 3511 will work, turn the brass cup upside down and it will fairly well seal.... or find someone selling NSN 2910-00-790-2300, then you will have the correct mil spec primary element. JT out
Jimma
Hartwell, GA
I got some at NAPA. I did find that at each napa I called to see if they were in stock only had one of the secondary filters on hand. So I would call first and they can usually get more in one day. Also every napa store I called quoted a different price.
LowTech
162
Arizona
Brass cup
Which way is the right way up? When I put in the second & final I had to have the cup domed up, On the primary it fit w/ the cup domed down.
