gunner_bear
- 1
- 0
- grand haven mi
where is the cheapest place to get oem military filters for the deuce? thanks
On the secondary and finail filter yes. However, I found my primary filter was different and the military had installed a washable one.is there anything that has to be done special to use the napa filters? any different gaskets? just remove current filter and replace with the napa?
Which way is the right way up? When I put in the second & final I had to have the cup domed up, On the primary it fit w/ the cup domed down.Napa gasket for OEM primary is #5131
Napa Gasket for the secondaries is #5070
There is no perfect primary available at any car parts place, military primary is different. The 3511 will work, turn the brass cup upside down and it will fairly well seal.... or find someone selling NSN 2910-00-790-2300, then you will have the correct mil spec primary element. JT out
