daschae
- 0
- 1
- Chandler, AZ
I have unlimited access to used motor oil, how much (what percentage) of motor oil can i burn with my diesel in my multi-fuel?
That was the pink liquid in the jug that was passed around the campfire at the Ga rally!I In the summer I use Wreckerman's Special Deuce Elixer
I would have thought there would be some possum squeezing's in that mix.I have had good luck with 50/50 WMO/ regular gas in the winter. In the summer I use Wreckerman's Special Deuce Elixer......30%WMO/30%WVO/30%straight diesel/10% gasoline
You mean just an ordinary sump pump? I got one laying around if that works it would be great. I just have to fight an filter on the entrance or exit or both?I use a cheap harbor freight water pump with a spin on filter base and 10 micron hydraulic filters. It will fill the 50 gallon tank in under 10 minutes. total cost was under $300. I've run 100% and it works well.
I have used this Duece Elixer of Wrecker's, in slightly different ratios, (actually more UMO).I have had good luck with 50/50 WMO/ regular gas in the winter. In the summer I use Wreckerman's Special Deuce Elixer......30%WMO/30%WVO/30%straight diesel/10% gasoline
