Windshield Washer
Billy Bobbed
13
Terre Haute,Indiana
Has anyone installed one of these windshield washers on their truck.I just wanted to know if they work very well,sense they are a hand pump and not an electric pump.Does it seem to spray on the windshield very well.Looks to be an easy install.Id like to get one for winter,they like to lay alot of salt on are roads here.
Crazyguyla
124
Altus, OK
I installed one once. If the winshield sprayer is has a conical top, it has to be moved farther from the windshield than proscribes int he instructions. Seems the original sprayer(pictured in the instructions) had adjustable nozzles. An electric pump could be worked into the system.
wsucougarx
68
Washington State
I've installed five of those kits. Once it's primed the first time, I get liquid with each pump after that. The trick is drilling the spout hole even, level, and far enough away from the windshield assy so you get a good stream where you want it. I made the mistake of drilling a hole and pulled up on the drill motor. It bent the sheet metal up. When I put the spout on it was squirting over my windshield onto the hardtop. A rubber hammer got things squared away.
Billy Bobbed
13
Terre Haute,Indiana
Im getting ready to put my washer on,can anyone tell me how far away you put your nozzle from the windshield.And where there parts missing in your kit like the rubber washer and nut for the nozzle.Thanks
steelandcanvas
86
Southwestern Idaho
The blueprints supplied with my kit showed the hole for the nozzle centered on the cowl and 2.5 inches from the bottom of the winshield. I just installed mine last night, I think I bought it from Ace Draven about 4 or 5 years ago. I will do the wet-test tonight, and report back. I also didn't get the nut and washer for the nozzle, it's nice to know it didn't fall out of the box. I also understand this thread is over 18 months old.
Speddmon
Blind squirrel rehabiltator
30
Cambridge, Ohio
Jonathan, do you understand that this thread is over 18 months old???
Oh, Wait a minute :p
steelandcanvas
86
Southwestern Idaho
Yessir I do. I was really trying to resurrect the thread to get any input on the install, especially since I drilled the hole in the cowl where the prints called for it to be. Seems as though this may not be correct.
Oooops! Didn't go all the way to the bottom of your post. :oops:
Dm35
Ny
Where did you get the kit?
Sent from my SM-N960U using Tapatalk
