asgtoolman
- 3
- 0
- Florence SC
I just went to the"ZONE" and picked up a Dorman #86913 brass starter switch for $14.99 +tax that does work [on the bench with a continuity tester] It is a 3 position switch with battery, ignition, solenoid. Connect one wire to the battery and one to the solenoid and you only get power when you are turning the key against the spring pressure, as soon as you release there is no power to the starter solenoid, so no grinding. IF IF IF you want a way to control some other small accessory you have added, you could hook it to the ignition terminal and you would be sure it was disconnected when you removed your key.
I had used a Dorman #85936 on my mule that only cost 8.99 but it is not all brass like this one, so I sprung for the extra 6 bucks this time.
There should be no reason to have ANY wire going to a ground for what you are trying to do.
HOPE ALL THIS HELPS!
