Power still being power, you can estimate it. One horsepower equals 746 watts. In DC circuits, power (watts) equals the volts times the amps.i wonder how much HP , running all that dual alt stuff takes from the engine. I would guess using math one could pall park it.
Obviously, your alternator is not putting out full output all the time. So usually you would calculate the normal running requirements of your vehicle. You can measure this with an ammeter or estimate based on the types of circuits and equipment you run.
Just to use round numbers, let's say that your vehicle requires an average of 20 amps steady-state to run. 20 amps times 28 volts equals 560 watts.
560 watts divided by 746 watts per hp equals 3/4 of a horsepower.
But we are not done. The alternator is not 100% efficient and there are parasitic losses (fan belt, windage, etc.). A ballpark is to assume 80% efficiency. This puts you right up around 1 hp.
Obviously, the amperage numbers above are illustrative but the 746 watts per hp is 'the law' and the 80% efficiency is a reasonable estimate.
To get an idea of the relationships involved, look at the engine hp ratings for gensets of a given wattage capacity.
