slave cables
jag7720
Kansas City, MO
I have a M1009 and a 2000 diesel chevy van
I'd like to put a slave receptacle on the van and build a slave cable to jump between the two ... I usually have to jump them once or twice on the coldest days.
Then I'd like to build an adapter for the slave cables to go to regular jumper clamps.
Anyone know where I can get all the slave cable ends?
I see the slave cable receptacles in ebay but nothing for the cables themselves.
Warthog
245
OKC, OK
With the M1009 being 24v and the Van 12v, how are you going to wire the cables? Or are you converting the 24v slave pin on the M1009 to be only 12v?
Westech
CPL
6,104
212
cow farts, Wisconsin
even if you do that (12V only) its NOT going to jump that truck. The only thing it would be good for is if the van went dead and you used the cucv to jump it (if cucv slave was changed to 12V)
Ebay is a good place to check.
was posted before I seen you hacked it to 12V. It will work
jag7720
Kansas City, MO
Why not... maybe I'm missing something. Isn't the slave receptacle attached directly to the batteries? Wouldn't that be the same as clamping on some civiy style jumpers to the battery?
Sephirothq
26
Trevorton / PA
1. does the van have two batteries in parallel?
2. does the blazer have two batteries in parallel?
3. is the slave connection hooked up for 12 volts on both the van and the blazer?
if the above is all true then yes it will work
Warthog
245
OKC, OK
His M1009 has been coverted to 12v, so he will be jumping 12v to 12v. Not an issue.
5,161
Ahh gotcha. If that's the case, why not just get quick connects from NAPA. I'm not sure how much the NATO connectors cost, but I'd bet more. (Unless someone has a source for them as surplus)
wilber
24
olathe kansas
I want to do the same thing, except use two pins for 12 volt and nato for 24 volt. That way I can use adaptors for one set of slaves to jump either 12 volt or 24 volt. I don't plan to mix and match.
Anyone know where I can get some two pin vehicle receptacles cheaper than $30?
319
Lieutenant
3,347
58
Michigan
Slave cables are kind of pricey. I use a set up similar to this for my 12V vehicles. I also have a set connected to the front battery on my CUCV.
Booster Cable, SD, 4 AWG, 25 Ft, 400 Amp - Jumper Cables - Automotive Maintenance Tools - Fleet and Vehicle Maintenance : Grainger Industrial Supply
Battery and Cable Connectors - Wire Connectors - Electrical - Grainger Industrial Supply
I don't surf e-bay so I have no idea what slave connectors run, but General Jim's Surplus (989-386-5425) in Clare Michigan has the newer style connectors for about $50 ea.
