- 4,038
- 116
- 63
- Ponchatoula LA
i called when my m816 was down stuck.. com wrecker company told me off road recovery was 450.00 per hour.. i too did the lava rocks and timbers they do work![What he said! :ditto: :ditto:](https://www.steelsoldiers.com/images/smilies/ditto.gif)
![2 Cents 2cents 2cents](https://www.steelsoldiers.com/images/smilies/icon_smile_2cents.gif)
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you, Sir, for that excellent explanation.dust7..Not from a movie (well I never saw it) I have carried out EXACTLY this proceedure in the British Army as a revovery mech. (active service). And I must have done it at least 6 or 7 time here in the U.K. with many of my past collection exploits. (I mind once long ago (60s) bogging down on "Ilkley Moor" A Vast expanse of VERY lonley BOGGY peat type terrain in a SCAMMELL 6x6 and that's H E A V Y!..took 2 days (well all one day and 1/2 the night in freezing mist!) only my jeep to get "tackle" to the scene. HA! tackle?? (I hear you say..) only tackle was spades shovels picks matocks a roadplate and gunplanks. SO it WAS on the ground (so what) that's the HARD work part. ok. We dug down (yes into the cold water) and THEN placed a steel sand runner and two sleepers crosswise under the front AND jacked that 13 ton load up and chocked it. After filling we place gun planks all the way back (proceedure previose to you) and drove it back. ( yeah....back once ..we HAD to do it TWICE (all over all round) before I drove clear back the way it had gone in and onto better terrain. DO NOT lose heart and get despondant...IF you had experience of this type of recovery It would be less daunting..just TAKES TIME method and persistance. The winch is not crappy..the poundage was FAR exeeded. (without blocks.) Deuce in thick mud / bog ground factor (at least) 2 1/2 times + rollong resistance + safety factor = shear pin NO CHANCE.:: ((if you had snatch blocks and wire lengths , it would need at keast a 6:1 compound direct pull. the winch would stand that ..BUT remember the "thing" it is all achored to must be able to stand a 12+ton pull" or you will be the anchor! Sounds like if you had done the (or do he prceedure) you WOULD move it out of there. (epecially as it wwas moving? before pin shear) just replace the pin and PREPARE THEN WINCH it out of there. it will come. GOOD LUCK. keep us posted...P.S. Just to show..found an old pic I had from years back as mentioned.
long as theres no rolloversIf it were me I would have just called Gimpy. He'll go anywhere.
sw
You run the winch cable under the truck and pull yourself backwards. Not the best choice, as you can tear something up. And it puts alot of strain on the winch.
Some good reading and you should keep a copy in your vehicle
Steel Soldiers
There appears to be a problem with the software the board uses. I was going to post the link for you as it is in the "Resources" section of this site. However, when I went to go to the resources (any of the choices) they all sent me back to the main listing op current postings.I remember reading when this was first posted that the link went to a scanned document circa 1950s-60s. Clicking on the link just goes back to a list of current threads. There's even one page from this later in the thread.
Can you repost the document/ link?
That would be for FM (field manual) 20-22 vehicle recovery.
Google FM 20-22 and you should be able to find a copy since the old site with the TM's is down.
Edit: here you go. FM 20-22 Vehicle Recovery Operations : DEPARTMENT OF THE ARMY : Free Download & Streaming : Internet Archive
On the left side of the page is a list, click on the pdf file and you can down load the manual.
Ah you mean this? This would be from the (uh Im drawing a blank right now). PS series?
This concept plagues me. Can someone please give me a reason how it works?Ah you mean this? This would be from the PS articles.
Try this link: VCU Libraries Digital Collections | Home
