kapnklug
- 1
- 18
- spencer,ny
Anyone ever try converting to dual electric cooling fans? I've done this for cheap on a gas-powered blazer, using two junkyard fans from two V6 air-conditioned chevy Lumina's. That wasn't so hard since the fans came with integrated shrouds, I just cut the shrouds and joined them with a plate in the middle, then mounted the whole thing top and bottom to the core support.
But the CUCV has those oil cooler lines running back and forth across the radiator, which is gonna make it tricky. Can anyone supply pix of such an installation? Or perhaps its up to me!
