Gunwriter
- 0
- 16
Question for the group.
I have had zero trouble with the air on my truck. Been starting it every day and letting it run due to the cold weather. The other night it got down to -5 F and the next day I went out and started the truck at 5 degrees F and then started my CUCV. I came back and noticed the air buzzer was still going off on the Deuce.
I checked and the air pressure was not going over 60 psi. I didn't have time to play with it yesterday so today I went and checked again. Same thing, pressure is slightly below 60 PSI. If I stand on the brakes and hold them to the floor it slowly goes down to 30 PSI.
So........what did I lose and where should I start looking. I hear no obvious leaks....
thanks in advance for all your help!!!
