- 2,102
- 28
- 38
- Delta Junction, Alaska
Just because you drain the air tanks after use, does not preclude frost problems in the system. It takes a drier or an alcohol snifter. Also the system has a lot of age on it and those various valves can get gummed up..... A silicone lubricant helps. Don't use a petroleum base lube.
