low air pressure, what happened?
rosco
Delta Junction, Alaska
Just because you drain the air tanks after use, does not preclude frost problems in the system. It takes a drier or an alcohol snifter. Also the system has a lot of age on it and those various valves can get gummed up..... A silicone lubricant helps. Don't use a petroleum base lube.
steelandcanvas
85
Southwestern Idaho
Solargizer on Ebay for less than that...heck here's one for $47 shipped.
SOLARGIZER 24volt includes lugs - eBay (item 300496376174 end time Jan-14-11 15:24:17 PST)
Hmmm, Solargizer has no warranty. The Battery Minder has a 5 year warranty. Solargizer doesn't work if you park your vehicle inside. The Solargizer is not a charger, it's just a conditioner. The Battery Minder does that and more.
I put the Battery Minder on my (2) 6TL's in the Fall, and in the Spring, I have a fresh set of de-sulphated, fully charged batteries. I also have one on my 10KW genset so that unit is always ready to go. Big difference between the Solargizer and the Battery Minder. As always, just my 2cents.
JCKnife
46
Kentucky
Very good! I would not present them as equals. Just another possible help for Gunwritr for less $$.
