11:00x20 duals on Deuce with snow chains
73m819
325
gainesville, ga.
there is a SS member selling 1100x20 chains in the classifieds for $ 50 a PAIR plus s/h, a lot better then almost $500 for 1/2 a pair of triple chains
JSBIRD69
19
El Paso, Colorado
Single chains on each axle
Thanks Ron! I spotted that member's ad and left him a comment.
It would seem I could cover all six axles for less than $250 shipped...and I'd have a tough time finding a deal that good anywhere else.
Thanks SS!
Jay
73m819
325
gainesville, ga.
The reason another poster said the chain will hit on the inside duel on 1100s, is because of the way the duels move out of line when making turns, the military truck has a lot more side to side movement that a OTR civi truck, I can't run inner duel chains on my 819s 1200s for the same reason.
Chaining up just the outer tire ought to be good enough, with the front and all four outers chained, you would be a real go, with the front and one set of rears chained, you would still be a go, just not a real go, eather way , you will be able to run over a stuck CUCV
JSBIRD69
19
El Paso, Colorado
Done deal!
Thanks again to those who were later posting than some others.
I've made the deal on the 11:00's, so that part of this mission is a done deal. (Thanks Cameron) :-D
I have also made a deal on enough single chains to cover the two front tires, and the outer tire on all the four rear axles.
The chains came from an SS member, and are military chains made for 11:00's.
Now all I need is some snow! ;)
Thanks to all.
Jay
emr
25
landing , new jersey
fyi I have brandy new 1100 ndtccs for 250 ea. in northern NJ can do better on the set . also a set of 1100 michelins for 3000 also brandy new ... fyi because this post is about 1100s on a deuce and that is why i had these, but sold both deuces, so they are not in the classifieds and am just throwing this out... :)
Flyingvan911
158
Kansas City, MO
A lot of guys like the 11.00x20 Goodyear or Michelin radial tires. They have a long life on pavement where as NDT's wear out quickly being bias ply tires.
cranetruck
75
Meadows of Dan, Virginia
Think about airing down when driving in sand and snow, 10 psi or even less. The large foot print reduces the pressure per square inch to that of a man walking. Bias ply tires are more forgiving aired down and let you drive on side slopes if need be.
rmgill
14
Decatur, Ga
I would submit that I have driven all around the Metro Atlanta area in our last two big ice/snow storms with chains on and found no issues. My configuration was chained up medium weight tire chains on the front axle and the rear axle, though I am not running duals, I'm running rear singles. 1100x20 G177s. I didn't find any problems with chaining up just the front and rear axles. Plenty of grip, directional control and no obvious wear. Since I was running on ice/snow, the diameter imbalance between the rear axle and the middle axle didn't seem to matter much.
The tire chains came from TireChains.Com
pitpawten
199
Centreville, Maryland
Not enough inside clearance on 11.00x20 duals (deuce) to run tri-rail (dually chains)
I just wanted to chime in here, the real issue with dually chains (tri-rail chains) on a deuce running 11.00x20 (in dual) is the distance between the inside sidewall of the inside tire and the suspension.
I had a member here measure his and it is only 1" distance between the two when at rest, no doubt less during flex.
There is a HIGH likelyhood that under flex the inside chain WILL rub and potentially catch on the suspension.
The distance between the front and rear set of duals does not seem to be an issue as there is 5.75" to work with and you should not see flex reduce that by much (if you do, check your dogbones : )
VPed
304
Clint, TX
There are threads that mention rear tracks and a truck with an original set of tracks was up for sale about a year or so ago.
