Where to buy D-ring shackles
epitts
-1
Terre Haute, Indiana
So where can I get the bumper shackles for a M1009 or the pins? I have three shackles and two are missing the pins. Tractor supply did not have nor did Rual King. HELPThanks
ralbelt
9
West Warwick, R.I.
i made mine, took a solid shaft cut to size, stack welded two washers on one end, drilled a hole on the other. Ground down the welds and painted.
3dAngus
102
Perry, Ga.
Tractor supply should have some 1" and 3/4" pins, but not exact replacements. they also have a close resemblence of the same shackle.
The 1" pins are rated at 25,000 pounds. Even so, I would just use them as a decoration on your bumper due to the unknowns.
I would only use good condition mil-spec pins for towing that came with the towbars. Not sure of your intended application.
Search Results
I should say though, tractors rear lift or 3 point hitch that use some of these pins, are capable of verticle lift greater than your Deuce weight, so I don't dismiss these pins as being weak or poor quality if they go on a tractor hitch. It's just that it becomes an unknown and I stay in my own personal comfort zone when using matching mil spec parts. These hitch parts aren't comparable to Harbor Freight, IMO, and much better quality.
CARNAC
The Envelope Please.
718
College Station, TX
I have about 8 or 10 left for $10 each which includes pins. Buy 2 and it's a medium flat rate box, buy 4 and it's a large.
Downside is I am completely overwhelmed at work right now. I am hoping to get free for the next two weekends but after that, I will be travelling and will probably not be free for nearly a month based on my current schedule.
Dirtflirt
Greater Metro Atlanta GA
D rings
Carnac, any chance you still have any D rings I just need 2 but could be persuaded to buy 4.
thank you in adv.
Dirt
