My apologizies for not updating this thread. To tell the truth, this part of the build (chasing leaks) is almost like the finish work on a homebuild. You know you're doing something but it looks like you haven't touched anything. I got all the leaks taken care of on the passenger side. Been a tedious process. Between having a day off and having it raining to chase leaks. Since I had the panels pulled I thought it would be a good time to install the slave cable plug onto the rear of the truck. I plan on installing a 4-6 battery bank to supply radios and power to the box. I bought a NOS m900 series battery two tier four battery box from my MV parts supplier. The rear slave receptacle will allow me to recahrge the battery bank with a 24v generator AND use this battery bank to slave my truck. I also plan on incorporating an AC recharger as well. Also in the plans is to incorporate a 24v battery isolator on a switch. This will allow me to charge the rear battery banks using the truck's generator. Need to dive into Ohms law and figure out recharging times vs amps and all that later one. On the exterior of the truck I put in a HMMWV antenna mount for a civilian multiband HAM antenna. This will not be a permanent mount. I'll just mount it when I need it. Below the mount you will see two 90 angle electrical conduit metal thingamagiggy (keep rain out). I went to Home Depot and mated a few parts together to come up with this. One will be for the antenna coaxial and the smaller of the two will be the SOLARGIZER's power wire & exterior rear lighting power wire (maybe solar panel power wire also).
I have also installed some exterior handles on the side of the van. They have absolutely no function at this point, just had them laying around
![Wink ;-) ;-)](https://www.steelsoldiers.com/images/smilies/icon_wink.gif)
On the front of the truck, I installed a second set of BLIND SPOT mirrors. These will serve but one purpose. These are my antenna tie down observation mirrors. I've got a ton of low lying trees in the area. Every once in awhile my antennas let go. Instead of having to stop the truck to see if they're stil tied down, I installed these for on the go viewing
I also installed an antenna mount to the fender for the CB radio. Right now I have an antenna base there just for looks.
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I know, I have entirely too many antenna mounts on this truck. But they will all serve a purpose once I start diving into the interior of the van.
Projects Completed:
Caulked exterior van Port/Starboard
Installed interior van panels starboard
Installed 24v Slave plug to rear of van
Installed electrical ports to the rear and starboard of van
Installed 4 whatever handles to van ext starboard
Re-installed int van panels starboard
Installed fender mounted antenna mount for CB Radio
In the planning phases:
mounting an M818 spare tire rack (minus tool box) onto the rear of the van
Battery isolator w/switch & ammeter for recharging van battery banks
tinting the cab door windows
EGT
aux fuel tank
wiring for aux power using a small 2000w AC generator
