treeguy
- 3
- 0
- Fort One Bay - Cape Cod, MA
With the suggestion from Smokinyoda I am posting this to help anyone looking to install the front winch frame extentions. This is a complete list of bolts needed to: mount winch frame extentions, your flipped bumper, and front shackles mounted top and on the bottom of your bumper to give you a total of four in the front which fits 7/8" standard shackles. This looks mean, but I needed it for 2" receiver mounting points. If you only want the top two you could trim the exposed threads. These nuts, bolts, lock washers are from MSC (industrial supply) 1-800-645-7270. They are a national supplier for the machinist industry. If you ask them to send you their Blue Book you will find supplies for any deuce project. The prices shown are from last year and may have even gone up since I ordered mine, but notice that the quality and price will definitly beat any local store. Some of the items are sold in packs or min. quantities but are still cheaper than your home center store. You'll figure out where they all go on your truck, don't worry.
These will be part numbers quoted for all grade 8 hardware:
86501970 1/2-20x11" bolt quantity: 4 $9.35 ea.,
86502564 5/8-18x11" bolt quantity: 2 $10.99 ea.,
74455031 1/2-20x1-1/2" bolts 50 pack min. $49.83/pack (you will use 32 of these),
85660157 5/8-18x1-1/2" bolts quantity: 4 $1.23 ea.,
85660207 5/8-18x2" bolts quantity: 4 $1.38 ea.,
85660306 5/8-18x3" bolts quantity: 4 $2.00 ea.,
05724844 1/2" gr. 8 lock washer 100 pack min. $9.27/pack,
05724869 5/8" gr. 8 lock washer 100 pack min. $15.61/pack,
67472282 1/2" gr. 8 nuts 100 pack min. $21.11/pack,
67472365 5/8" gr. 8 nuts 50 pack min. $0.39/ea. = $19.50/pack.
This will get it all together, if you look thru the cataloge, they have higher grades like Lake Erie Grade 8, Armor Coat, and T9, but the prices get higher. Like I said I paid just about $200 with shiping and got them the next day because they have a branch in my state. I prefer lock washers than the lock nuts that the military use, you can't thread them by hand.
When you got the frame extentions, did you also get the three 1/2"diameter tubes and the two 5/8" washers that are 1/4" thick that go under the grill mount brackets to take up the empty space? I thoroughly appologize for telling you anything that you already know, I just want to help so you don't miss anything. It took me a long time to figure the measurements when I did mine, so I know what its like.
TIP FOR ASSEMBLY: I always coat bolts with marine grease as well as mating surfaces. This repells water (ie. corrosion) at joints and keeps threads strong by prohibiting corrosion. (Boat mechanic tip) Next assemble everything together FINGER tight first!!!!! Due to any minor misalignments, if you bolt the whole rig together as you go, things may not line up and you'll have to go back and loosen things up. This will cause a giant headache. If all the bolts are left loose you can tweek where you need to.
Once its all together then tighten the he!! out of the nuts, but be a little easy on the 1/2"er's they could strip out. If you go too tight you will deform the lock washers (done it). I'm not sure of the exact torque for 1/2" fine and 5/8" fine hardware but I used a 1/2" drive breaker bar by hand to finish mine off tight. Some of the nuts are accessable with an air gun but the others you need to wrench by hand will definitly have a lesser torque so I opted to tighten it all by hand so they are all uniform.
Then go back and check them all again. There are 50 bolts so you may miss one or two, look for them they are there. I hope this can help anyone converting to a truck w/w. Good luck!
