JeffAS
- 0
- 0
- Lessburg/Ohio
Do you have to use a tube, I was looking at buying some 395 and when I asked about tubes they told me I did not need them
I would say somewhere between 6-9 inches, I don't have one right now to measure but it is a big difference, it still looks cool but If I cold get both to mirror the rears that way it would be real cool. I am making some wheels with a 0 offset so the mounting portion of the wheel is dead center no offset either way, tires will stick out pretty good but will have a gnarly stance.I had a problem one time with an 1100x 16 when running a 900x16 tube in it so I went up to larger tubes so the tube wouldn't be inflated to an extreme amount just for it's everyday life. I would definitely recommend saving the couple of bucks to run the larger tube than ...making due... with stock tubes.
ALSO, QUICK QUESTION FOR THE GUYS ON STOCK WHEELS, 395'S, NOT FLIPPING THE REAR HUBS AND RUNNING REAR WHEELS OPPOSITE THE FRONT WITH THE CENTERS IN: What is the difference between front track width to rear track width??? I have some old M34 single style wheels I've thought of using to make the offset less. Please throw a tape measure across your truck for me~! Thanks!!!![]()
I like the look of the 395's but not that large difference in track widths. I thought maybe using the original single style wheels (non dual able for rear) it would bring the front out a couple inches and the rears in a couple inches. Hmmm...for that matter maybe just run all of them and flip the rear hubs. Still tossing it around...Thanks for the estimate.I would say somewhere between 6-9 inches, I don't have one right now to measure but it is a big difference, it still looks cool but If I cold get both to mirror the rears that way it would be real cool. I am making some wheels with a 0 offset so the mounting portion of the wheel is dead center no offset either way, tires will stick out pretty good but will have a gnarly stance.
As for the question about flipping hubs and dishing in wheels the only thing you can do it tub the bed about 6" on each side to make room for them, not hard to do but you will have to know how to work with sheet metal a little bit.
For the bed/tire interference problem:
can't you just add some 3"x3" box tube between the deuce frame and the 105a2 bed frame?
