jgb680
- 3
- 0
- Chattanooga, TN
Has anyone installed a tachometer on a CUCV? Can it be done?
There are many ways to do it.Has anyone installed a tachometer on a CUCV? Can it be done?
before someone tells you to check the wiki or use search, http://www.steelsoldiers.com/cucv/62765-tiny-tach.html
Tiny Tach Rules!
Travis
If you delete the vacuum pump, what sends the vacuum signal to the trans and the fuel pump? Sorry for the hijack.I went the delete the vac pump route and installed a pick up off a humvee with the tack
I'm curious about that too, anyone?Has anyone swapped in an OEM GM tach from the same vintage trucks?
