Unforgiven
- 18
- 0
- Las Vegas, NV
My components:
Left to right are 3.5" ID to 4" ID adapter, 4" ID to 5" ID FTE Resonator, 5" OD short pipe, 5" ID Pittsburgh Power muffler, 5"OD 68 degree bend, 5" rain flap. Sorry for the shadows in pic.
Inside view of the resonator. It's a right-hand corkscrew like a sea shell surrounding a straight-through core.
Inside the assembled, welded muffler stack including the 68 degree tip. Notice there is quite a direct path through the stack to minimize back pressure.
This is where I cut off the stock exhaust
Yes, I know. It's hideous! This summer I am making a Crew Cab out of the truck. When I do this, I'll relocate the muffler stack behind the Crew Cab. That will also lower it about a foot or so. This is a very temporary setup.
I used the 68 degree mandrel-bent pipe as the tailpipe tip to make the gasses exhaust out, up, and back all at the same time. That way the sound is carried up and away from the cab.
There's the flapper flapping away while I'm enjoying being a passenger for a change.
It doesn't look bad from inside the cab. Still, It's a little top-heavy for now. Notice the paint scraping from the mirror bracket as the truck vibrates over the dirt roads. It doesn't move much, just enough to bother me. I tend to be a perfectionist. But for now ... good enough.
Now for the meat and potatoes ... empirical results. Be patient. It'll take me a few minutes to upload the pics & edit. I think you will find the data useful.
