M101A2 violent braking!
Nonotagain
Parkville, MD
Hey does anyone know how long the breakaway chain should be, mine was missing and id like to have one.
On my M116a3 the chain is a plastic coated cable and is around two feet long. It has a snap hook on the end so that the length is adjustable to you safety chain hook-up.
My M101a3 uses a piece of chain and again is around two feet long with a "S" hook in the end fastened to the safety chains.
Pawnshop
23
Austin/Cedar Park Texas
According to the man I spoke with this morning, Toledo Actuators does not sell direct to the public! He gave me the name and number of a dealer in Houston that should have the part, still on the hunt.
Pawnshop
23
I installed the shock in my trailer and MAN what a PITA! The trailer now stops smooth and straight, and I am happy, but I don't ever want to do that job again! It took me and Buckmaw to get everything back together, three hands and some cussing...
Ratch
Chester County, PA
Note!
If you have one of these trailers with a worn shock, and you disable the brakes and procrastinate replacing the shock, check all the bolts holding the actuator on the trailer, and lunette onto the actuator. I found the a-frame bolts under-torqued, and the lunette bolts very loose. If the violent/rapid oscillation loosens up the shackle studs keeping the lunette on the actuator, you could be testing the safety chains more than you'd like to, and stopping the mass with your tailgate or bumper.
I pulled a trailer out yesterday that I hadn't taken on the road yet, and the shock was badly worn out. Holy crap was that violent braking, it was like getting pounded with a 1000lb hammer unless I coasted to a stop. And this was one of the nicest (and most expensive) trailers I've bought yet... I have another one with a slightly worn shock that oscillates a little when braking with a full load or not at all when empty, but not like the other.
I stopped somewhere and dropped $1.50 on a grade-8 3/8 bolt and locknut, and drove around for another 4 hours of city/highway without issue. Braking wasn't even a big deal, so without load, I have no problem driving around with the brakes disabled.
If I never get the payload heavier than a couple hundred pounds, I'd probably never fix the shock. But I'm selling it, so I did knock $100 off the asking price, though.
