Jerry Can Strap
3rdmdqm
135
Woodbine Maryland
Am I the only one that can't figure out how to attach the Jerry Can strap? I have seen some unbolt the can bracket bottom plate and run a single stap underneath. The one I got was a two piece. One of the pieces was already sewn in a loop but the only way to secure it to the slot/hole would be to run a dowel or something trough it wider than the slot to keep it from pulling through. I cut the stitching, fed it through and then riveted it in place. I wound up attaching the strap using 1/8" diameter aluminum rivets with 1/8" backing plates. We'll see how long they last. I then covered the ends with super glue to prevent fraying. Is there an easier way I missed?
emr
25
landing , new jersey
it goes under the holder and bolted down, and yes u are the only one... :) , and up the back side and over the can, that way it does not get lost or stolen, they work fine with the strap just under the can too, now put it thru the holes of course...
3rdmdqm
135
Woodbine Maryland
That would be for a one piece correct? The two piece one I have would not be long enough to do that. I'm guessing I was sent the wrong strap.
maddawg308
762
Appomattox, VA
I used all combinations:
1. a one piece strap wrapped through the bracket and under it, bolted in place
2. a two piece strap, each end attached to the bracket
3. a one piece strap, double looped through the bracket holes but NOT underneath the bracket
I like option 3 better, since no rivets are required but you don't have to unbolt the stupid bracket either.
Lex_Ordo
Long Island, NY
Last year I was able to purchase and sell sets of USGI factory ordered two single piece straps, on ebay that not only go vertical under the bracket and over the top of the can, but also around the waist, and secure the can horizontally too.
I have since sold out.
The straps must go under the bracket and over the top of the can (either under the handle or webbed through it) or they will bounce out of the tray and fall off the vehicle. I tested this out last summer.
Unless you have the two piece straps that are looped and sewn on either end, the single long straps are way easier to order and replace when they fail.
You can see the can in this pic.
DUG
Senior Chief/Moderator
73
Mesquite, NV
The lockable metal straps are great, except they don't work for the plastic cans.
CycleJay
Marietta, Ga
Hi guys,
Thank you for this thread. I was wondering how to strap in my Jerry can too,
now since I read this I unbolted my bracket and put the strap underneath.
So now since I did that, my Jerry can is much more secure, and does not move
around as much in the bracket, and now someone cannot steal the strap. LOL
gungearz
northwestern indiana
I went to menards and picked up some 1" load baring straps for $4. Threaded it up under the front slot and thru the back slot and just put it thru the slip lock. Both straps are on the top of the Jerry can. Its not sitting on the strap. So the weight can wear the strap to break. Been holding my full Jerry can for over 1500 miles and never had a problem.
