area52
- 5
- 38
- San Bernardino CA
did you ever sell the heaters?
The A2 version was used as an electronic repair shop. The lifgate was used to lift heavy equipment so it would not get damaged trying to get it into the box.This is such an awesome piece of equipment. Can anyone tell a noobie what specific function it served? I am sure there were many varied uses, but it doesn't seem to be a logistics / supply vehicle.
I can envision battle planning and/or command and control going on in it, though.
Just curious.
LC
Goldneagle, sorry for the late post. Can you fit a hardtop on that thing with the van body clearance above the cab? I have only seen them with soft tops which I think is strange considering what it is.
I might be buying one and would like to start figgerin as much as I can about it! Nice truck BTW![]()
Aww NO WAY! I was just there, why didn't I see that??Eastern surplus has a couple of them with hardtops....
eeeeek, a little bit more pricey though huh?get the m934a2 that they have![]()
slightly moreeeeeek, a little bit more pricey though huh?![]()
GE - Is there any manufacturers data anywhere on your liftgate? I'd like to install one on my truck if I can figure out who makes them like that. When it is up does it fold up under the back of the frame or does it cover the back doors so you have to put it down before you can open the back doors? thanks!
S
