joesco
- 1
- 18
- Hampstead, NH
Treeguy,
You should contract with the DOD as you write in English, simple enough for an ape to understand! Thanks for nice "cheat sheet". I am going to print it out and use it to re-time the unit this week.
Yes, pumps going until they slow down, preheat for 60 to 90 seconds, then start. Runs for several seconds then dies.
The rebuilt pump came without a button. I ordered a new button from Ambac based on the calculations in the TM and assistance from Tom to confirm it was the right button and installed it using the darn "jesus" ring.
As far as removing the two injectors, the small lines to each injector are not coming off as the small nuts are stripped. So removing the injectors will be my last resort as I will have to cut the lines off to remove both injectors. Then more expense as I will then need all new lines!
Thanks again!!
Thanks again!!
