- 14,607
- 4,695
- Buchanan, GA
Me too. So far so good!I got caught up with work today and decided it was time to check the oil since the o-rings change on the oil cooler. Nothing but oil. Those o-rings were the problem apparently.![]()
![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
Well I've been fighting a mixing of coolant and oil in the oilpan. I've had some NASTY looking oil/water snot in the top of the valve covers. I got the heads off yesterday. The gaskets were the new style 1 piece head gaskets. But I see no signs of a blowout. I don't see any cracks on the head surface either. Nor have I noticed any on the block deck. The only thing odd to note is the #1 cyl liner lifted out of the block when I rotated the engine over to look at the cyls. #2 also ever so slightly moved upwards as well. I realize there's a lip on the liner that "locks" it into place. But would there be any harm in cleaning it up a bit and applying a little locktight around the liner? Anything else I should be looking for? I'm just at a loss as to why this thing runs good, but mixes oil/AF.
How about here:I emailed Memphis about rod bolts, but they only have used ones. (Bleah!) .
