Schwitzer Turbocharger
stancanpara
Montpelier VA
My 1964 M275A1 has what looks to be a rather large turbocharger on it... I've never seen one that looks like this on other Deuce and a halfs...
I'm looking for more information on this... Searches on SS has so far been rather fruitless...
Has anyone else had any experience with vehicles similarly equipted ?
gimpyrobb
dumpsterlandingfromorbit!
27,791
786
Cincy Ohio
That is the turbo from the 427lds motor. They make good boost. I have one of every turbo but that one. I'd like to find one someday.
Also, looks like your missing a band clamp on your air tube to turbo.
stancanpara
Montpelier VA
Thanks gimpyrobb. So it's an "older" turbo on a 'newer' engine?
I had not seen one labeled like that so was afraid it might have been an aftermarket job...
My understanding is that the LDS-427 was the predecessor to the LD-465... is that right? So you say it's 'correct' for this truck?
Recovry4x4
LLM/Member 785
1,827
GA Mountains
If I recall correctly, EMR had an LDS 427 in the can a while back. Don't know if high scrap prices claimed it or not.
NDT
7,421
Camp Wood/LC, TX
Your truck (1964) would have been delivered with a LDS427 engine. I wonder why the data plate does not say M275A1, as the M275 is gas. Your data place says "multifuel", so it is the correct original data plate. Your truck is a rare survivor.
1958 M274
North GA
Notice that this truck still has the early A1 pipe and hose from the air cleaner to the turbo. Correct early 25 amp generator with a mechanical regulator too...
stancanpara
Montpelier VA
The best I can tell, I believe this truck came from DRMO in the 70s, was used for several years logging and then sat in the log yard as a log stop for 20 plus years where I found it and brought it home... They used and abused it but didn't do any work to it, so it's pretty much (configuration wise) as it came from the army....
It was shuffled out of the army before they started their computer data base... I know this because CARNAC had nothing on it.
Bill W
47
Brooks,Ga
My 71 M-35A2 (C) had a Schwitzer on it as did a friend of mine have one on his also (D), I was told ( second hand ) they were stock on the D model LDT 465 engines, I just don't remember it looking that big
stancanpara
Montpelier VA
Here are a couple more picts... And something interesting to note, look at the Serial Number...:wink:
SCSG-G4
PSVB 3003
5,400
3,493
Lexington, South Carolina
Stan,
From a pure collector standpoint, it's a VERY GOOD thing. Esp the 'serial number' which indicates it's one of the first with the multifuel engines. They put the model number there because they had not made up new data plates for the new designation yet. A 'transitional' designator. A very good candidate for becoming a trailer queen for someone with deep pockets!
stancanpara
Montpelier VA
Stan,
Thanks. Very interesting... Know anyone with 'deep pockets' looking for one?;-) "I" just want a M275 A1 or A2, doesn't matter which... In the end, I just want a road tractor, no real need for one... I just want one... just because... 8)
It's been rode hard and put away wet...(Loggers are HARD and EVERYTHING) she's pretty rough but she RUNS very well! Also of note, the numbers on the frame match the data plate as well...
1958 M274
North GA
Since the turbo and all of the related parts are A1, but the engine is an early non-turbo A2, I bet when the engine was installed they used the A1 parts to add the turbo to the replacement 478 cubic inch engine.
Joe
WillWagner
3,164
Monrovia, Ca.
I did a recovery at Barstow for Bboomerbootcamp. His truck had that turbo. Seemed to run OK.
stancanpara
Montpelier VA
I think it's interesting that everyone seems to be talking about a whistler and non whistler, like there are ONLY those two, Model C and Model D out there:drool:..... and this is neither:confused:, and it 'looks' like it's about 3 times as large as the C or the D models... and it's NOT a whistler.
It still runs pretty well...
stb64
17
hohenfels germany
i never call those turbos C or D, as their correct designation is 3LJ319 for the whistler and 3LM39 for the non-whistler.
the LDS427-2 engine came from the factory with 2 different turbos, too: 4-450 for early engines, and 4D454 for late engines
stancanpara
Montpelier VA
Thanks! That is most interesting! Do you know why they changed from the 4D454 to the 3LJ319? Was there a problem with the 4D454?:?:
