motormayhem
- 18
- 18
- Tucson, AZ
If you have a compressor you could try cracking the lines right before the lift pump and using a rag or a tennis ball with a hole on both sides to seal the filler and then pressurize the tank to no more than about 5 psi and see if you can get fuel to come out at the lift pump. If you have fuel to the pump and not past there then you know it is the pump.Thanks, guys! Lift pump? Sounds like a plan. Of course, I'll have to wait until tomorrow to get one as nothing is open today. IF that doesn't solve it, what's next on the list of possibles?
Also, would spraying WD-40 or ether into the intake while cranking help or hurt?
Someone else chime in as im not sure but I think you could try the WD-40 in the intake as long as you disconnect the glowplug system.
