Jerchambers
- 0
- 16
- Craig, CO
Ok so, I have been trying to troubleshoot something for a while now and with no luck. About two weeks ago I replaced the brushes and the 12v bus bar in my driver side alternator. The idiot light was coming on and the power cable was loose. So, after replacing the parts and as the alternator guy tested the alternator and said it was testing good, I saw the idiot light come on again. It goes away when the gas pedal is engaged and lights up when it is released. Now when I first start Hulk in the morning or after a long period of sitting, it becomes difficult to start. It will turn over then stall, and after cranking for about 10 sec the second time it starts with a little gas and the volt meter shows yellow. After he warms up the volt meter shows green and almost in the red at the far right of the gauge. The fuel gauge acts like a RPM gauge as well.
I have also installed recently a 900W Power Brite Inverter to the radio hook up in the rear of the passenger seat. This inverter is shutting down due to excessive load. I am not an electrician and know nothing about this stuff other than what I have been learning from this website. I am at a loss and have been waisting valuable time trying to find what the problem is. It seems when I fix one thing something else comes up.
