Clutch Alingment Tool
electraman
Charlotte, nc
Ok… So I have to take out my pressure plate. Is the special clutch alignment tool needed, or can I go to any auto parts house and get one?
Thanks in advance!
Marlboro
Mullica Hill/NJ
Yes you will need one, Not sure if a truck repair shop would have one that works. I think eastern surplus listed it on there web site. I believe its a rare tool, friend of mine cut off an input shaft and used that.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
I believe Westy is right, it's a 10 spline. The part that makes it odd though is the end for the carrier bearing is only 3/4 diameter. Most 10 spline 1 1/2" diameter transmission shafts are 1" I believe. I got an old input shaft from a truck junk yard and had my local machine shop turn the end down for me.
Jakob
Louisville, KY
I used a couple of sockets. I forget the sizes however. The larger socket was a 1/2" drive impact socket and the other was a 3/8" drive regular socket, both deep well. I used a little tape to make the fit snug. Transmission went right in and it didn't cost me a dime.
The regular socket fits the input and the impact socket fits the clutch disk hole. Use tape on the regular socket until it's a tight fit in the impact socket and TA-DA... home made clutch alignment tool.
jasonjc
289
Gravette Ar.
That about how I did 2 or 3 of mine. A socket and extention:grd:
But hey if some one fines one of the plastic ones that works right please post up the part number here.
Jakob
Louisville, KY
[SIZE=-1]Clutch Alignment Tool - 1-3\8 10 spline, .67 pilot. For Models: TO20, TE20, TEA20, TO30, TO35. [SIZE=-2](Part No: 1112-5996)
Would this one work?
[/SIZE][/SIZE]
