Why so Hot?
motormayhem
Tucson, AZ
Runs around the 190* thermostat when temps are below about 90*. For temps between 90-105* it will run about 195-200* in traffic or at lights, about 200-205 down the highway, and as high as 210* on long hills. Has a new water pump, thermostat, fan clutch, and radiator was fixed and cleaned about a year ago. The only not stock cooling system piece is a 10"x18" transmission cooler mounted right in front of the radiator (see pic), but stock blazers had a/c in front of radiator so how is that different? Whats causing my temps or are they ok for 100* weather?
Thanks,
Motormayhem
southdave
ripley, oh/TDY Lordstown,Oh
Thanks,
Motormayhem
did you turn up the fuel? did you flush the block? yet maybe the trans contrib. to heating as well engine oil? if all else fails try a 180 t-stat 19 bucks at ss-diesel.
motormayhem
Tucson, AZ
I fuel is stock setting. Didn't flush the block, but I did run a hose through the block till it ran clear and used a radiator flush kit from twice because the first time it didn't cleanup all the way. I tried a 180 stat and it didn't change so I went back to the 190.
maddawg308
785
Appomattox, VA
You're forgetting an obvious suspect - the gauge is faulty and reads a little high. I've seen it on all sorts of MVs, mostly deuces, but I'm sure CUCVs can have it too. You might check the temperature cable from the thermostat to the cab, not sure how hard it is to change out the temp gauge in the cab, but you might try that too.
OL AG '89
15
Kingwood, Texas
my 2cents.
First question is, what is the correct "TM supplied answer" for the temp of a 6.2L normal operating conditions?
FROM
TM 9-2815-237-34
Cooling system:
Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Liquid with fan and radiator​
Operating temperature (normal) . . . . . . . . . . . . . . . . . . 190°-230°F 88°-110°C
So according to the TM you are within specs......
Woodsman
New Albany, IN
my 2cents.
FROM
TM 9-2815-237-34
Cooling system:
Not to mention the impact of the aftermarket A/C condenser. That can dump a lot of heat into the radiator and it only gets worse as the ambient temperature increases.
DokWatson
Wasilla, Alaska
I will also point out you can't fully flush the block without pulling a plug on the bottom, water will just run right over the sediment on the bottom. Gotta stick a thin punch in there and rattle it around to break it up.
OL AG '89
15
Kingwood, Texas
Are we still discussing this?
the operating range is 190 to 230.
you said the hottest it gets is 210.....
YOU are WITHIN specs.....
don't do anything, IT AINT BROKE!!!!:deadhorse:
motormayhem
Tucson, AZ
my 2cents.
FROM
TM 9-2815-237-34
Cooling system:
Somehow im just reading this...Anyway thanks a bunch I had been looking for an "official" answer for a while and couldn't ever find any specs. I heard everything from never above 190 to 215 will crack the heads to 230 is where the idiot light comes on so thats overheating. I kinda figured it was ok since my cummins is in the red at 230* as well but wanted to error on the safe side. Thanks for the official info!
