395s 16.5 G20 Tube Size Help
frodobaggins
Ruston, La
395s 15.5 G20 Tube Size Help
Through reading the forum I have decided to use 12-20 Tubes. (Unless anyone can convince me otherwise)
I am mounting these on stock rims btw.
I have found these tubes at Summit Racing. I want to make sure this is what I am thinking it is before I order them. Please advise :)
Carlisle Tire and Wheel Company 322460 - Carlisle Tire Tubes - Overview - SummitRacing.com
I sure don't mind good links on good places to buy either. Thanks for the help.
goldneagle
1,426
Slidell, LA
I looked at the link and it lists 14/80R20 so I think they should work for you! :grd:
snipe071
Tomball, TX
I hate to bring posts back from the dead, but did these tubes work for you? I am sitting here about to pull the trigger on the exact same set of tubes?
thehaas
matamoras pa
valve stem has to be bent when putting two halfs together,tube covers 11 12 13.80 same tube.after installing i think more reliable with out tube ,you dont have flap like original to protect tube on rim also dont have slot in rim like stock .they seem to be holding one did go flat looked like something small put hole in tube.we made video on you tube under bodyshop18336 hope it helps others
