Almost destroyed my truck..
73m819
319
gainesville, ga.
use a gas ax on the nuts, then a BFH and a punch bar for the frame mount and unbolt and remove the axle mounts, place on some blocks, then the BFH
BlizzardX23
12
California
kinda lost there
I got the torque rod end out of the axle mount...I'm using a few different punches...and a small sledge hammer but still cant get the torque rod end out of the frame mount. What other tools have you guys used?
Rattlewagon
SW PA
I thought so. I was thinking that one could make a whole new torque rod using some 3" ballistic fab joints and some DOM. the only problem would be that I believe the largest I have seen would accommodate a 3/4" bolt.
more work than its probably worth...
BlizzardX23
12
California
the **** taper is whats holding the bolt into the frame still...otherwise, once the nut comes out, it'd be an easy swap....
I tried the torch...still no luck....I just picked up my Remington 870...wonder if that would work...........
topo
231
farmington NM
When I had to replace the torque rods on my M131a5c the mounts where welded to the axle so there was no taking them off .so after taking the nut off I welded a chain link to the stud and used a load binder to put a good pull on it .then hit the mount with a hammer some I had to heat up with a torch .
276
22
Hobart, WA
I swapped all mine to longer arms when I stretched the axles for the 14.00's - the trick is as follows:
Strike the top and side of the mount the stud it is stuck in; you will need to hit the to and side of the bracket quite hard - use a wedge of steel or a prybar between the differential and the tip of the stud (run the nut back on until the top of the nut is flush with the end of the threads so you don't mushroom the stud)
Putting out ward pressure on the stud you will beat the bracket until it pops loose (hit it where the paint is missing in the picture). The goal here is to temporarily deform the socket of the bracket so the taper breaks loose. It will seem like you are getting no where and then they will pop free...
Heat may help but I have always done them cold - tapered tie rod ends are the same.
Matt
22
Hobart, WA
Also if you need to get the upper two in the frame out you will have to take the u-bolts and lifting bracket off the spring - make sure the truck is blocked up well and it helps to have a floor jack on each axle so the spring can be neutral and just rest on the walking beam pivot... Or one tire on the ground with all the truck weight on the lower control arm bracket like in the picture.
HTH
Matt
